Misfiring and codes p0351, 353, and p0354
2005 MAZDA TRIBUTE
116,000 MILES • 6 CYL • 2WD • AUTOMATIC
NASER NASER
  • 836 POSTS
Changed all coils, still misfiring but runs much better than before. Same codes, removed PCM looks good inside no corrosion or wet. Plugs looks good and dry. How do i go about making sure it is not the PCM, or catalytic converter on these, any other possibilities?
Jan 4, 2020 at 12:02 PM
Good afternoon,
You should have changed the plugs when you had them out. That would be good preventive maintenance
Anyway, there is a TSB on this issue. It indicates that when the coils fail, it damages the PCM . This will require replacing plugs, coils and the PCM. Did many of these in the old days.
POWERTRAIN CONTROL MODULE (PCM) PROGRAMMING - WDS
When the PCM is replaced, the new PCM must be programmed with the old module's configuration information. The following step by step procedure guides you through replacement of the PCM in a Tribute using WDS or equivalent tester with B18 or later software.
NOTE: This procedure was performed using WDS or equivalent tester B18 software Later software versions may have a slightly different screen order or content.
Procedure 1
(For 3.0L vehicles with PCMs that have tear tag numbers of JYB2 or JYB3. For all other PCM tear tag numbers, see Procedure 2.)
NOTE:
When replacing a powertrain control module (PCM), the following items are required:
WDS or equivalent tester with B18 or later software loaded
Minimum two ignition keys for reprogramming PATS (be sure to ask customer for ALL spare keys)
Obtain new PCM part number AJ08-18-881F.
With old PCM still in vehicle follow procedure below.
NOTE: When performing this procedure, if the WDS or equivalent tester PTU is not docked and connected to 115V-120V, we recommend that a battery charger be installed on the vehicle battery and turned ON to a maximum charge of no more than 20 AMPS to keep the vehicle battery up to capacity. If you exceed 20 AMPS it will damage the WDS or equivalent tester PTU.
1. Connect WDS or equivalent tester DLC cable to vehicle's DLC connector (lower portion of dash in front of driver).
2. Press "16 PIN" then "All except those below". Press tick.
3. Screen shows cable hookup. Turn ignition switch to ON. Press Tick.
4. Screen shows WDS or equivalent tester communicating with PCM "progress bar" and "Operation in progress".
5. Wait until WDS or equivalent tester finishes collection of PCM information (hard drive light quits flashing). Then the "Vehicle Specification" screen appears with VIN # information. It asks you "Is this correct? Press "Yes" if information is correct.
6. Screen appears to fill out R.O. information and mileage. Fill out information (or skip this). Press tick.
7. With screen showing "Vehicle Specification", press "Tool Box".
8. Another menu appears Select "Module programming". Press tick. "Please Wait" appears.
9. Then another menu appears. Select "Programmable module installation" then select "PCM" then press Tick.
10. Screen shows "Set ignition switch to OFF (position 0)". Turn ignition switch to the OFF position. Press tick.
11. Screen shows "Install a new module in vehicle". Replace the PCM with the new unit. Press tick.
12. Screen shows "Remove the fuses for fuel pump and additional fans as this may cause interference and battery drain during the programming process". Press tick.
NOTE: There are two 50 amp fuses (on 3.0L) labeled "Main Fan" and "Add Fan" Remove only the 50 Amp fuses to deactivate the fans Fuel pump is a mini fuse 20 amp (position #6) at front end of fuse box.
13. Screen shows "Set ignition switch to the ON position". Turn ignition switch to the ON position. Press tick.
14. Screen shows "Downloading data" box with "progress bar". Please wait 2-3 minutes.
15. Screen now shows" Set ignition switch to the OFF position". Turn ignition switch to the OFF position. Press tick.
16. Screen now shows "Set ignition switch to the ON position". Turn ignition switch to the ON position. Press tick.
17. Screen shows "Set the ignition switch to OFF (position 0)". Turn ignition switch to the OFF position. Press tick.
18. Screen shows "Calibration has been loaded and checked". Press tick.
19. Screen shows "Re-install fuses for fuel pump and additional fans". Press tick.
20. Screen shows "Obtain a PCM label and fill in the PCM data shown with the date on the WDS or equivalent tester screen. Install in the appropriate position (New label should be in the new PCM part box). DO NOT FILL OUT PCM LABEL AT THIS TIME! Press tick.
21. Screen shows "start engine. Do not depress throttle". THIS IS INCORRECT! You must follow the below procedure to Start the vehicle:
Turn ignition OFF, Turn KEY ON (Count 3 secs. security light is ON solid). Turn key OFF, remove key.
Insert 2nd key, turn key ON, (security light stays ON for 3 secs. goes out) then start engine. Turn OFF engine, remove key.
both keys programmed.
22. Now with Key OFF, press "Select Systems Options" or "Menu" ICON (at the upper right hand side of screen). Press "EXIT" and push the green tick. This will return you to the "Vehicle Specifications screen.
23. Now press the "Close session" ICON (lower left hand side of screen, 3rd ICON) and press "delete" (deletes session). Press tick.
24. Now, Press "16 PIN" and "All except those below". Press tick.
25. Screen shows cable hookup Turn ignition switch to ON. Press tick.
26. Screen shows WDS or equivalent tester communicating with PCM "progress bar" and "Operation in progress".
27. Wait until WDS or equivalent tester finishes collection of PCM information (hard drive light quits flashing). Then the "Vehicle Specification" screen appears with VIN # information. It asks you "Is this correct?". Press NO.
28. Then the "Vehicle Specification" screen appears again and asks "Is this correct?" Press NO again.
29. Screen shows "Incorrect Calibration Programmed." Press tick.
30. Screen shows To enable WDS or equivalent tester to identify PCM, please enter one of the following information:
PCM part number or
Calibration number (7, 10, or 15 digits) or
Tear tag number
Press tick.
31. Press the light blue box area next to "tear tag" and enter "JYB2 or JYB3" (whatever the tear tag number of the new PCM is). Press tick.
32. Vehicle specification screen appears asking "Is this correct?" Now press YES.
33. Screen shows" Turn Ignition switch OFF". Turn ignition switch to the OFF position. Press tick.
34. Screen shows "Remove the fuses for fuel pump and additional fans as this may cause interference and battery drain during the programming process". Remove the fuses for fuel pump and additional fans. Press tick.
35. Screen shows "Turn ignition switch ON". Turn ignition switch to the ON position. Press tick.
36. Screen shows "Downloading Data" box with progress bar. It takes approximately 2-3 minutes.
37. Screen shows "Turn ignition switch OFF". Turn ignition switch to the OFF position. Press tick.
38. Screen shows" Turn ignition switch ON". Turn ignition switch to the ON position. Press tick.
39. Screen changes to "progress bar" and then changes to "Vehicle Specifications" with VIN # and asks "Is this correct?" Press Yes.
40. Screen to fill out R.O. information appears. Press tick.
41. "Vehicle Specifications" screen appears. Now Re-install fan and fuel pump fuses.
42. Now select "Tool Box", then "Module Programming". Press tick. "Please wait" appears.
43. Now select "Module Reprogramming" and "PCM". Press tick.
44. Screen should say "No later calibration is available on the system for this PCM. The latest level for this vehicle:1U7A-12A650-AYB". Now, fill out the PCM label mentioned previously, with this information and install it next to the vehicle emissions label on the hood.
45. Press tick.
46. Now turn Key OFF, press "Select Systems Options" or "Menu" ICON (at the upper right hand side of screen). Press "EXIT" and push the green tick. This will return you to the vehicle specifications screen.
47. Now press the "Close session" ICON (lower left hand side of screen, 3rd ICON) and press "delete (deletes session). Press tick.
48. Disconnect WDS or equivalent tester cable. PCM is now programmed with the latest calibration.
Procedure 2
(For all 2.3L vehicles and 3.0L vehicles with PCMs that have tear tag numbers of SJC0, SJC1, SJC2, HQP1, HQP2, or HQP3.)
NOTE:
WDS or equivalent tester with B18 or later software loaded.
Minimum two ignition keys for reprogramming PATS (be sure to ask customer for ALL spare keys).
For 2.3L - obtain new PCM part number YF11-18-881.
For SJC0, SJC1, and SJC2 - obtain new PCM part number AJ08-18-881 F.
For HQP1, HQP2, and HQP3 - obtain new PCM part number AJ25-18-881.
1. Connect WDS or equivalent tester DLC cable to DLC connector on the vehicle (lower portion of dash in front of driver).
5. Wait until WDS or equivalent tester finishes collection of PCM information (hard drive light quits flashing). Then the "Vehicle Specification" screen appears with VIN # information. It asks you "Is this correct? Yes or No?" Press "Yes" if information is correct.
7. If vehicle is not equipped with ABS, screen will appear showing the "Standard equipment modules and Fail-ABS". This is normal. Press "Exit". Press tick.
8. With screen showing "Vehicle Specification", press "Tool Box".
9. A menu appears Select "Module programming". Press tick "Please Wait" appears.
10. Another menu appears. Select "Programmable module installation" then select "PCM". Press tick.
11. Screen shows "Set ignition switch to the OFF position". Turn ignition switch to the OFF position. Press tick.
12. Screen shows "Now install the new module". Replace the PCM with the new unit. Press tick.
13. Screen shows "Remove the fuses for fuel pump and additional fans as this may cause interference and battery drain during the programming process". Remove the fuses for fuel pump and additional fans. Press Tick.
NOTE: There are two 40 amp fuses (on 2.3L), 50 amp fuses (on 3.0L) labeled "Main Fan" and "Add Fan". Remove only the 40 Amp fuses to deactivate the fans. Fuel pump is a mini fuse 20 amp (position #6) at front end of fuse box.
14. Screen shows a "progress bar" on the bottom of the screen and "Please wait".
15. Screen shows "Set ignition switch to the ON position". Turn ignition switch to the ON position. Press tick.
16. Screen shows "Downloading data" box with "progress bar". Please wait 2-3 minutes.
17. Screen now shows "Set ignition switch to the OFF position". Turn ignition switch to the OFF position. Press tick.
18. Screen now shows "Set ignition switch to the ON position". Turn ignition switch to the ON position. Press tick.
19. Screen now shows "Set ignition switch to the OFF position". Turn ignition switch to the OFF position. Press tick.
20. Screen shows "Calibration has been loaded and checked". Press tick.
21. Screen shows "Re-install fuses for fuel pump and additional fans". Re-install fuses for fuel pump and additional fans. Press tick.
22. Screen shows "Obtain a PCM label and fill in the PCM data shown with the date on the WDS or equivalent tester screen. Install in the appropriate position (New label should be in the new PCM part box). Press tick.
23. Screen shows "start engine. Do not depress throttle". THIS IS INCORRECT! You must follow the procedure below to start the vehicle.
Turn Key ON, Engine OFF (KOEO) (Count 3 secs security is ON solid), remove key.
Insert 2nd key, turn key ON, (security stay ON for 3 secs goes out) turn key OFF. Then start engine Turn OFF engine, remove key.
Both keys programmed.
24.Disconnect WDS or equivalent tester from vehicle. PCM replacement procedure is completed.
Jan 4, 2020 at 12:52 PM
