Misfire, codes p0302 and p0303
2000 FORD ESCORT
100,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
ABGREEN
Misfire on two and three (p302 and p0303). checked for vacuum leaks, replaced plugs, wires, coil pack, switched injectors with one and four. Compression is good, codes always come back.
Feb 2, 2019 at 3:08 PM
SEVAG P
  • 405 POSTS
Hello thanks for using 2CarPros.
Checking actual values for misfire counter if its count at only at idle speed or at all conditions.then run our guide:
https://www.2carpros.com/articles/engine-misfires-or-runs-rough
Thank you let us know the results.
Feb 3, 2019 at 4:56 AM
Can I ask what the spark plugs looked like in each cylinder? White, grey, black?
Feb 4, 2019 at 2:23 PM
ABGREEN
Thanks for your reply. Plugs look good (we switched plugs to 1 and 4), misfires only at speed if you stay off the freeway no codes are set, customer was able to drive for two weeks with no codes until she went on the freeway. No discernible miss until around 2,000 under a load.
Feb 6, 2019 at 11:31 AM
Yep, sounds like you may have a flat camshaft lobe. Lets remove the valve cover to inspect. here is a guide to show what I am talking about:
Feb 6, 2019 at 1:42 PM
ABGREEN
Thanks, I bet you are right. It never crossed my mind, never see that in newer cars (I'm 72 so to me any thing built after 1985 is newer to me). If we ever get it back I will let you know.
Feb 6, 2019 at 2:28 PM
Feb 7, 2019 at 10:20 AM
