Codes P1505 and P1507, misfire?
2004 HYUNDAI GETZ
107,940 MILES • 1.6L • 4 CYL • 2WD • MANUAL
EPRJ25
My car has been misfiring when idle or driving but i changed the crankshaft sensor and now it doesn’t misfire when idle but only when driving. I used a scanner and it showed 2 codes which were P1505 and P1507.
May 11, 2024 at 4:22 AM
This model Hyundai isn't offered in the US, but I suspect the codes are the same with other 2004 Hyundai vehicles. So, I attached diagnostics for both codes below. The diagnostics came from a 2004 Hyundai Accent, which is offered in the US.
The codes are related to the idle air control circuit. I don't know if that is where you are seeing problems. Take a look at the diagnostics and let me know if they help.
I hope this helps. Let me know.
May 11, 2024 at 8:58 PM
EPRJ25
Yes, thanks for that. I was able to fix the idle air controller and now the scanner only reads one code which is P1507 (idle speed control actuator.)
May 14, 2024 at 2:06 AM
That indicates the coil driver has a short to either power or ground. The same diagnostics apply with this code as I attached above.
This appears to be an electrical issue, so make sure the wiring is in good condition and the connector is as well.
See pic below.
May 14, 2024 at 6:13 PM
