I have stored codes for a misfire on all cylinders, cam position sensors, crank shaft position sensors.
I've replaced those sensors, changed the timing chain, taken the catalytic converter off to see if it's clogged and it was fine. I've changed the VVT solenoids, PCV, coil packs and spark plugs. I've changed the fuel injectors and cleaned out the intake manifold. I've got 500 PSI at the fuel rail at idle and around 2,500 PSI upon acceleration.
I've still got a misfire, not sure which one yet and I can't rev over 1,600 RPMs.
Apr 16, 2022 at 8:12 AM
