Have you monitored fuel trims to confirm this is rich? I don't think it is necessary as it is a safe assumption but I don't like to make assumptions because if we are wrong every thing from that point is wrong.
However, if we have a rich exhaust then that means the issue you are having is a misfire that is not burning all the fuel. So that raw fuel is going into the exhaust and it is burning in the converter which is why the temp is higher coming out.
So if it is not clogged then we have to go back to the engine and cover the basics. Pull the plugs and get a picture of them so we can see if they are fouled. If they are they need to be replaced. I attached below a chart showing spark plugs that are worn. That will give us more info as to what the issue is.
Then we may need to replace or at least try and clean the injectors because they may be sticking and dumping too much fuel.
Let us know what the plugs look like and we can go from there. Thanks
Dec 23, 2020 at 6:07 PM
