Minor electrical gremlin with front passenger door lock
2003 TOYOTA RAV4
181,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
WILLIAM RANKEL
  • 17 POSTS
So I have been having an issue with the front passenger door lock. I replaced the actuator with a new actuator but the car now only "unlocks" on the electronic switch but does not "lock" when pressing lock on either the passenger or driver's side door lock switch.
I tried plugging in the older actuator but the problem remains. If I unplug the old or new actuator entirely, the doors will lock again using the lock switch but obviously this does not solve the problem because the passenger door actuator is not plugged in, during this scenario.
Any ideas?
May 26, 2017 at 12:59 PM
HMAC300
  • 48,601 POSTS
check switch to see if power is going through it first. may not be. check all fuses in picture then have a mechanic scan for codes as the pass door ECU may be the problem.
May 26, 2017 at 3:43 PM
WILLIAM RANKEL
  • 17 POSTS
This is still a problem with the design of these actuators. I figured out that moving part of the new actuator is causing this problem. When the door key is inserted and turned to the left, the lock will lock using the electrical control. But it is so touchy that it will lock and unlock the car very fast. Then the new actuator will unlock the car and not allow you to lock. I've replaced the actuator already... is there a step I am missing in terms of the door locking shaft alignments?
Oct 19, 2017 at 11:45 PM
Can you send a picture of what you are talking about please?
Oct 20, 2017 at 2:34 PM
