2003 Mini Cooper No AC pump operation
2003 MINI COOPER
83,000 MILES • 4 CYL • 2WD • AUTOMATIC
MARTYDE
The AC punmp on this vehicle is not operating. I have checked the AC fuse(s) and the relay with no issue found. It is not low on freon. The car does have climate control with all indications inside of the cab as being normal. I have tried to access the clutch energize wiring but it is impossible to access short of pulling the pump. No check engine light.
Any suggestions?
Cordially,
Marty de Almnana
Apr 26, 2008 at 1:13 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
The first thing to do is get a pressure reading done on the hi & low side this will give a better indication as what is going on, do this first.
mark (mhpautos)
Apr 27, 2008 at 12:33 AM
MARTYDE
I did check the pressure and it is appropriate. There is no way to check the HI side perssure since the AC pump is inoperable.
Apr 28, 2008 at 8:38 AM
