Check engine light came on and it was for a torque control solenoid, but I was waiting until the weekend to replace it. However, on the way home from work the check engine light went off, but it was revving at 4500 rpm and would only do sixty five mph.
Then it would go back in the normal rpm range and accelerate back to seventy mph until it done it again.
As I pulled over, the engine shut off and would not start again, so I was towed.
The temperature got a little over 200 but not in the red.
Checked the oil today and it was milky, and so I drained it.
Also swapped out the TCC solenoid, too.
Is this a head gasket leak?
Aug 12, 2017 at 12:57 PM
