Using an OBD1 Scan Tool (OTC3211) that I was able to purchase recently, it states there is a MIL-Code 27 (Output driver circuit does not respond to control circuit) fault at Injector 6 Control Circuit. I have checked continuity from the injector connector back to PCM connector, and when doing so, I have also cleaned and added dielectric grease at all the connections. I have done the 10 volt test, which it passed.
I have been having this problem for a while. Unfortunately, it is erratic. Sometimes the engine works fine for a couple-hundred highway miles, and other times it happens within a couple of city-driving miles. Sometimes it appears to happen when decelerating, but also when driving on open road at highway speeds.
Feb 28, 2020 at 12:13 PM
