hi, hope you can help or advise. i noticed a coolant leak on the mg and sent it into a garage for repair i was told the water pump needed replaceing. after the repair 2 days later the car was leaking again this time I was told the head gasket had gone. we had this repaired at the cost of 555.00. The day it returned we noticed it was blowing clouds of white smoke from the exhausts..the garage pressure tested and said the car was ok and it may burn off. Afetr another one hundred miles the car was still blowing white smoke. The garage are now telling me that because we only had a headgasket and gasket kit replaced and skimmed and not a decoke that there could be oil stems faulty and oil getting into the head but wont know this until they have stripped it all down at our cost and possible head gasket replacement again. I have been told by many mechanics that white smoke indicates water getting into the head or a cracked block The garage is telling me this is not the case as its had a new headgasket and has been pressure tested, i also thought if it was oil getting into the head it would blow blue smoke not white. could you please offer any advice or assistance.
Jul 12, 2010 at 2:47 PM
