Two weeks ago I had brake pads installed, ball joints, bearings, sway bar links, rotors and calipers. I took it to the mechanic because the brakes were bad and I ended up getting this work done. It has been making a metal scraping grinding noise while driving and the noise is more apparent when I drive at low speed. The noise stops when I lightly tap the brakes. Returned to the mechanic two times and he said he does not hear anything. Also, I know I have a bad muffler. But this noise was apparent before they worked on it.
Jun 4, 2018 at 3:55 PM
