Good Evening Sergeant,
By the end of this, this truck is going to be 100% new. :)
I see the issue you are having with this line. I am not seeing it either. However, I attached a picture of the slave cylinder below just to confirm we are talking about the line that threads into it?
If so, I would just make my own. You can get about 12 inches of straight brake line and then bend it and flare the other end.
Here is a video that shows how to do this. It is not that complicated, even a Navy guy could do it. :)
https://www.youtube.com/watch?v=sO43p4ZFUiM
I think the only other solution that I can think of for this would be to go to a salvage yard and find one on another vehicle. However, if you have the original one then you can just copy the bends if it has any.
Lastly I would suggest getting one of the line kits shown below and then just bend the line and when you get it correct, cut off the remainder and then put the threaded nut and flare the line.
Sorry I don't have a better answer but I suspect this is what most people are doing on this one.
Thanks
Sep 19, 2021 at 6:40 PM
