metal grinding noise after changing back brakes
2005 PONTIAC GRAND PRIX
150,000 MILES • 3.8L • 6 CYL • FWD • AUTOMATIC
SHAN21
Changed back brakes. hear grinding sound when starting to drive.
Aug 28, 2017 at 8:27 AM
STEVE W.
  • 15,113 POSTS
Did you change the pads and rotors? How about the parking brake shoe? Those have a bad habit of rusting and falling apart under the rotor.
Either way you will want to look them over and see if there is something assembled wrong or maybe the fronts are also worn.
Aug 28, 2017 at 8:46 AM
HARRY P
  • 2,292 POSTS
Also if the caliper bracket bolts and slide pins aren't perfectly tight enough then the caliper and/or bracket will rattle around. It could sound like a grinding sound if it starts touching the rotor. Seen it happen.
Aug 28, 2017 at 2:47 PM
