Message "traction active" turned on
2004 PONTIAC MONTANA
124,000 MILES • 4.2L • 6 CYL • 2WD • AUTOMATIC
LISA MCELROY
Message says, "traction active" and then it makes a semi loud hum.
Jun 28, 2022 at 3:46 PM
Yep, the traction control/ABS is active while dumping pressure to the brakes. let's run the codes to see what they say so we can fix it. It sounds like the ABS module is bad but to tell for sure follow this guide and video:
https://www.2carpros.com/articles/anti-lock-system-testing-and-repair-abs
Jun 29, 2022 at 11:57 AM
