Radiator fan doesn't shut off
MERCURY VILLAGER
BLIASAK
1996 Mercury Villager/186,000 km/3.0 L engine size
After driving my van when the engine gets warm the radiator fan starts working but doesn't stop.It just keeps working.At the beginning I thought I turned on the A/C by mistake but I didn't.
I want to point out that when I start the car the fan is off.
Thanks in advance for any ideas what could be the problem. :)
Nov 7, 2007 at 9:31 PM
You have 3 relays 2 of them is for high an 1 for low. Have it tested when it checks out-get the coolant temperature sensor check if its good and all wiring test good for shorts and opens -its coming from the computer which is responsible for energizing the relays.
Nov 7, 2007 at 9:53 PM
BLIASAK
[quote:04800da138="rasmataz"]You have 3 relays 2 of them is for high an 1 for low. Have it tested when it checks out-get the coolant temperature sensor check if its good and all wiring test good for shorts and opens -its coming from the computer which is responsible for energizing the relays.[/quote:04800da138]
Thanks.I guess I will have to see a mechanic.
Nov 8, 2007 at 6:10 AM
