Im having a hard time. The sensor that is described as being the ECT (elect. cooling temp sensor) with the Ltgrn/red wire and blk/yel wire when bypassed with a paper clip does nothing. I straight wired the fan from the battery and it works fine on low and high. Voltage on the two pins of the plug is 4 volts. Book says its supposed to be 5. Is that the issue?? I dont think so. From coresponding with another guy on yahoo, there is possibly another sensor that actually controls the fan. It is supposed to be located on left rear of engine. Could someone please tell me where that is?? I take it as being on the firewall side of motor drivers side under intake plenum. I have torn the air induction plenum and throttle body down and out of the way and cannot locate a sensor. Someone please help me before i set this van on fire. Do I have a pcm problem maybe?? Im pretty good with a wrench. Nobody at my local Napa, Oreily's, or Advanced Auto can give me any help. Im trying to help out my grandfather and get this thing on the road and out of my yard. As you can tell Im frustrated. The haynes book is wrong and of no help. Chilton supposedly does not make a manual.
Help
jwb
Mar 15, 2008 at 1:50 PM
