Is there a TCM/PCM in a 1999 Mercury Villager Estate? If so can it cause problems such as no reverse? I have this vehicle and had no issues till I changed the tranny oil. Because a nut would not come off the filter I did not change it. No burn, no metal frags were found in pan. After I changed the fluid I tested the car in forward and reverse and then rechecked and leveled the fluids. I let this van sit for three days and when came back to it I had two problems, no reverse and an electrical drain. I did read how you test for shorts and will try that.
Drives well in forward barely moves in first and will not move in reverse.
Jan 20, 2007 at 5:30 AM
