CAUTION: When battery is disconnected, vehicle computer and memory systems may lose memory data. Driveability problems may exist until computer systems have completed a relearn cycle.
Removal & Installation
Disconnect negative battery cable.
Raise and support vehicle.
Remove engine splash shield.
Remove generator adjuster bolt.
Remove 2 generator mounting bolts and support generator.
Rotate generator to access electrical connections.
Disconnect electrical connections and remove generator from vehicle.
To install, reverse removal procedure.
Tighten fasteners to specification
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 7, 2008 at 9:44 PM
