1996 Mercury Villager tail lights work, brake lights will n
1996 MERCURY VILLAGER
180,000 MILES • 6 CYL • FWD • AUTOMATIC
FRANKPATTIE
My 96 villager brake lights will not go off. Even with the vehicle not running. I pulled the fuse and that shut them down. The tail lights still work when the lights are turned on. I am not a mechanic but I can fix stuff when given the proper direction. Any help would be greatly appreciated. Thank you.
Jan 30, 2010 at 9:10 AM
SHIRRELL
  • 4 POSTS
I had the same problem with mine. I had to check the brakes every time I stopped other wise it would drain my battery! I put some wd 40 up under the pedal assembly and have never had the problem since. Apparently pretty common with the Villagers...
Feb 20, 2010 at 11:10 PM
