1996 Mercury Villager CV HALF SHAFT REMOVAL
1996 MERCURY VILLAGER
145,000 MILES • 6 CYL • FWD • AUTOMATIC
KWKOPPI
i AM HAVING TROUBLE REMOVING THE DRIVER SIDE TRANSAXLE FROM THE AUTO TRANSMISSION OF A MERCURY VILLAGER GS. I BOUGHT THE ONLINE MANUAL FROM MITCHELL AS RECOMMENDED. I HAVE THE HUB ASSEMBLY OFF AND FREED AT THE OUTER END. I AM TRYING TO PRY FROM THE TRANSMISSION HOUSING BETWEEN TRANSMISSION CASE AND OUTER RACE OF INNER END OF HALF SHAFT). I CAN SEEM TO FREE IT FROM THE INTERNAL CIRCLIP AS THE MANUAL SAYS. IS THERE SOMETHING ELSE TO BE REMOVED FIRST (BOLTS?, BRACKETS?) i SEE THERE IS A BRACKET THAT HELPS SUPPORT THE TRANSMISSISON. IT DOESN'T APPEAR TO INTERFERE WITH WHAT I AM TRYING TO DO. AM I MISSING SOMETHING? THANKS
Nov 30, 2008 at 6:18 AM
BMRFIXIT
  • 19,053 POSTS
Your not missing any
it could be very tough to come out
try to position two 2 pry bars ,one on either side of outer race ,between outer race and tranny case ,pry gently outward to unseat clip
CAUTION ensure pry bar does not damage tranny case ,oil seal outer race
Nov 30, 2008 at 10:33 AM
