1995 Mercury Villager water pump
1995 MERCURY VILLAGER
142,000 MILES • 6 CYL • FWD • AUTOMATIC
LORENZOD
I've been noticing a noise the past couple of weeks comming from under the hood like a bad drive belt pulley. I hear squeeks and knocking sounds that a bad bearing would make. Today I see that coolant is leaking from the pump area. also after further inspection I can see play in the pumps pulley main bearing shaft while the engine is in idle. I'm almost sure the pump is bad and needs to be replaced, but my question is are loud knocking and squeeking noises common on bad water pumps or should I be looking for something else? The knocking is not comming from the engine such as a rod knock I'm sure of that. Any help wil greatly be appreciated. Thank you , Larry
Jan 23, 2008 at 4:27 PM
BMRFIXIT
  • 19,053 POSTS
[quote:adbd315cf2="lorenzod"]Other Category problem
1995 Mercury Villager 6 cyl Front Wheel Drive Automatic 142000 miles
I've been noticing a noise the past couple of weeks comming from under the hood like a bad drive belt pulley. I hear squeeks and knocking sounds that a bad bearing would make. Today I see that coolant is leaking from the pump area. also after further inspection I can see play in the pumps pulley main bearing shaft while the engine is in idle. I'm almost sure the pump is bad and needs to be replaced, but my question is are loud knocking and squeeking noises common on bad water pumps or should I be looking for something else? The knocking is not comming from the engine such as a rod knock I'm sure of that. Any help wil greatly be appreciated. Thank you , Larry[/quote:adbd315cf2]
why don’t you disconnect the belt and start the car for a bit listen if noise gone
or spin the pulley one at a time
also check the idler and tensioner and AC comp.
Jan 23, 2008 at 6:15 PM
