1995 Mercury Villager Only blows heat while excellerating
1995 MERCURY VILLAGER
150,000 MILES • 6 CYL • FWD • AUTOMATIC
AL3177
MEMBER
FOLLOW
The heater blows great heat while excellerating, but when you let off the gas, the air from the heater turns cool again
Nov 27, 2009 at 11:19 AM
CERTIFIED EXPERT
Test or replace the thermostat and check coolant level for a start
Nov 28, 2009 at 4:53 AM
AL3177
MEMBER
I already replaced the thermostat and the coolant level is ok.
Someone said that there's a little door that has to open to let the air through and maybe that's the problem. I don't know.
Thanks,
al
Nov 28, 2009 at 7:45 AM
ANDREWBASHAM
MEMBER
I have the same type of problem with my 98 Villager. If I hold the engine at 3000rpm the rear hearter works as well. Could our problem be air in the system? Would "bleeding cooling system" help?
Nov 28, 2009 at 8:42 PM
ANDREWBASHAM
MEMBER
I dusted off my Haynes Repair manual for 93-01 Villager.
Chapter 1-23 talks about refilling the system after
servicing the cooling system. It goes step-by-step
on bleeding the system.
It takes a little time but it worked!
Setting still in the driveway and I got hot air front
and back!
Grace,
Andrew
