1995 Mercury Villager Coolant leak
1995 MERCURY VILLAGER
14,700 MILES • 6 CYL • FWD • AUTOMATIC
TINKERTOY
Somewhere around throttle body iis a coolan leak. Cannot locate suffuciant diagrams to determine source. Neither Ford if Nissan(Quest) has been helpful. Repair manual does not say anything in heating/cooling section; there are references to coolant hoses in fuel/echaust sections, non specific. Help!!!
Nov 14, 2008 at 10:25 AM
DMSCAR
  • 9 POSTS
I have a 95 Quest (same car) Just got thru replacing the KNOCK SENSOR.There is a coolant hose that runs under the Plenum (hope I spelled that right) and feeds into it... mine was leaking also... it's a hassle to get to (remove Plenum) but it can be done.
Take your time! GOOD LUCK if you haven't already done the job.
Dec 11, 2008 at 1:39 PM
