1994 Mercury Villager exhaust leak ,crossover pipe
1994 MERCURY VILLAGER
170,000 MILES • 6 CYL • FWD • MANUAL
MOLLYMEW
is it possible to repair the crossover pipie with a patch welded over the leak
Jan 5, 2009 at 12:08 AM
BLUELIGHTNIN6
  • 16,542 POSTS
So long as the patch is made of material that is capable of doing the same job as the crossover pipe material then it should work, that is assuming the welding job is done cleanly and correctly. If a spot is missed when welding, then the leak will still be there escaping through the patch.
Thanks for using 2carpros.com!
Jan 5, 2009 at 12:13 AM
