1993 Mercury Villager Turn signal short circuit
1993 MERCURY VILLAGER
180,000 MILES • 4 CYL • FWD • AUTOMATIC
FCAMPBEL
The turn signal fuse burns out regularly. I thought it might be weather related or movement related but while sitting at an intersection, on a dry day, waiting to turn, the flashers were working normally, then suddenly stopped because the fuse blew. Over the years it has become more frequent. Can a bad flasher unit blow the fuse? If I have to try and track down a short, what is the easiest/best way to do it?
May 24, 2008 at 8:23 AM
INVESTORDUDE
fcampbel,
I have same problem with my 1993 villager. Did you find out what was the problem?
Thanks,
[quote:f609859950="fcampbel"]Electrical problem
1993 Mercury Villager 4 cyl Front Wheel Drive Automatic 180000 miles
The turn signal fuse burns out regularly. I thought it might be weather related or movement related but while sitting at an intersection, on a dry day, waiting to turn, the flashers were working normally, then suddenly stopped because the fuse blew. Over the years it has become more frequent. Can a bad flasher unit blow the fuse? If I have to try and track down a short, what is the easiest/best way to do it?[/quote:f609859950]
Jul 5, 2008 at 11:31 AM
