overheating
MERCURY TRACER
ALLISTERFIEND2
I have a 1993 Mercury Tracer and the temp gage
keeps reaching hot. I have replaced the radiator and
I make sure that it has water and coolant. And I don't know what else could be causing it. I also don't
have the cap for the coolant recovery tank. Could that be the problem? And I have looked everywhere
for the recovery cap. And I have not been able to locate one. Please help!!!1
Jul 12, 2007 at 1:04 PM
SLAMMER
  • 15 POSTS
Are you sure that the (electric) radiator fan is turning on when it is hot? You can try and turn your a/c on max, turn temp to max cold. When the engine is warm and running this should engage the electric fan. If not you may have a bad fuse/relay, temp. switch, or even a bad fan. You have to eliminate 1 and go to the next. If the fan is working it could be the water pump too? Hard to tell with out being there in person. :oops:
Dec 20, 2007 at 8:01 PM
