1997 Mercury Tracer Sparks Only in 1 and 4
1997 MERCURY TRACER
85,000 MILES • 4 CYL • FWD • AUTOMATIC
MARKTRA82
The car was overheated and damaged the head along with piston 4. So I rebuild the bottom end and got a decent used head from a salvage yard. The car ran great for about 1,000 miles then all of a sudden it stopped getting spark in piston 2 and 3. I replaced the coil, plug wires, and plugs and still no spark. I've checked the timing and it's perfect. compression is 120 in each cylindor. The only thing I can think it could be is the computer. Is there anything that else that it could be ? I'm stumped
Feb 10, 2009 at 12:13 AM
Sounds like you're on the right track with the computer- the computer picks up the input signal from the CPS and in turn tell the ignition control module which coil pack to fire-
Feb 10, 2009 at 4:13 AM
