1995 Mercury Tracer sensors
1995 MERCURY TRACER
85,000 MILES • 4 CYL • FWD • AUTOMATIC
THOM043
  • 18 POSTS
Could you tell me the cam and the crank sensors are located. I was told the engine codes that have my engine light on are one of these sensors.
May 8, 2008 at 5:27 PM
ROB2008
  • 258 POSTS
On your vehicle the crank shaft position sensor is located :
Under hood, passenger side, lower engine area, front of crankshaft pulley, mounted in engine block
The camshaft Position Sensor is located :
Under hood, center, rear engine area, mounted on center upper rear of engine block.
Hope this helps !
-Rob
May 8, 2008 at 6:03 PM
THOM043
  • 18 POSTS
[quote:2b4146fe26="Rob2008"]On your vehicle the crank shaft position sensor is located :
Hope this helps !
-Rob[/quote:2b4146fe26]
May 8, 2008 at 7:17 PM
THOM043
  • 18 POSTS
can the crank sensor be changed with take any of the motor apart
May 8, 2008 at 7:19 PM
ROB2008
  • 258 POSTS
1.9L Engines
See Figure 5
Disconnect the negative battery cable.
Raise and support the car with safety stands.
Remove the left-hand front fender splash shield.
Unplug the CKP sensor electrical connection.
Unfasten the sensor retainers and remove the sensor.
Location of the CKP sensor-1.9L engines
To install:
Install the sensor and tighten the retainers to 40-61 inch lbs. (5-7 Nm).
Attach the CKP sensor electrical connection.
Install the left-hand front fender splash shield.
Lower the car and connect the negative battery cable.
-Rob
May 8, 2008 at 7:54 PM
