1994 Mercury Tracer no power on take off
1994 MERCURY TRACER
10,000 MILES • 4 CYL • FWD • MANUAL
GEORGE1966
car runs fine till you tke off then no power bring up rpm its fine
May 21, 2010 at 11:23 PM
Check and test the following below
Oxygen sensor
Catalytic converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Could also be an ignition system problem
May 22, 2010 at 1:32 AM
