1993 Mercury Tracer noise from idler pulley - I think
1993 MERCURY TRACER
114,000 MILES • 4 CYL • FWD • MANUAL
BAAS1219
I am hearing a noise that I think is coming from the idler pulley assembly. Like a ticking. Do I need to replace the idler pulley and if so, is it only held on by that one bolt?
Nov 28, 2009 at 9:36 PM
MERLIN2021
  • 17,250 POSTS
If you remove the belt, spin all pulleys by hand, any that have a roughness or are hard to spin, replace, the three usual suspects are idler, tensioner, and A/C, Idler and tensioner are held by one bolt, then pull off, install is the reverse of removal! The other is the alternator, if it has a roughness, replace the whole thing, that's due to bad bearings inside it!
Nov 29, 2009 at 6:48 AM
