NO SPARK
MERCURY TOPAZ
CARTROUBLE40
1992 MERCURY TOPAZ 11.9 VOLTS @ COIL BUT NO FIRE AT THE PLUGS ??? IM CONFUSED !!!! ANYTHING WOULD BE A BIG HELP. THANKS
Nov 15, 2007 at 10:23 AM
Inspect and test the coil,distributor pick-up,ignition control module, if it has also the CPS/CMP sensors
Do this disconnect the coil wire at the distributor ground it to the engine while cranking it over -do you have spark-if not continue to troubleshoot the above components. Got spark investigate the rotor and cap it has to make it out there to get to the plugs.
Nov 15, 2007 at 10:49 AM
