1993 Mercury Topaz belt won`t turn
1993 MERCURY TOPAZ
LEE SIMS
Engine Mechanical problem
1993 Mercury Topaz 4 cyl Front Wheel Drive Automatic
the engine runs but the belt won`t turn and pulleys don`t turn. what could the problem be?
Jun 1, 2010 at 4:05 PM
If the engine is turning and pulley/belt is not-sounds like its slipping check the belt tensioner
Jun 1, 2010 at 4:13 PM
LEE SIMS
nope. that`s not the problem. crankshaft pulley isn`t turning either. if that`s not turning then there is a problem with the crankshaft. so what could it be?
Jun 1, 2010 at 4:26 PM
Your engine is seized-up could be due to coolant in the cylinders or a main bearing is welded on
Jun 1, 2010 at 5:23 PM
