stabilizer bar link
MERCURY SABLE
GEOFFREESE
2002 mercury sable 126000 miles
I need to replace the drivers side stabilizer bar link. Is this a straight forward repair of taking out the old and putting in the new or are there any tricks or anything special I need to do. Do I need to support the wheel to take any pressure off the link or just jack it up and change it. Thanks
May 11, 2007 at 2:42 PM
GEOFFREESE
[quote:bf95e8b797="justanold"]HELLO! Nothing special here. jack the car up to relieve downward pressure to where the tire just leaves the ground then lower just a bit. replace..then repeat on the other side. they are the same age. a pry bar helps facilitate replacement and only unbolt one side at a time. 8) 8) 8)[/quote:bf95e8b797]
Thanks This helps a lot.
May 11, 2007 at 11:46 PM
