possible bad door sensor
MERCURY SABLE
RICH120865
  • 12 POSTS
1997 mercury sable overhead valve 134,000 miles.
after putting car in drive and going the doors are supposed to lock automatically. well, mine doesn't and the door ajar light in dash panel stays on and also the dome light stays on. how can i fix this or is it a problem only dealership can fix?
Apr 2, 2007 at 4:54 PM
RICH120865
  • 12 POSTS
actually it is working now but it has done this before where it will work for awhile then quit again. so eventually it will quit again. any help will be appreciated. thanks
Apr 23, 2007 at 6:47 AM
SERVICE WRITER
  • 9,123 POSTS
Unlimited space is available, just type til your hearts content.
You don't have to use those particular chemicals, for that matter I just use a thin lubricant that is comparable to wd-40. Just spray the latches on the doors liberally, open and shut the door about 15-20 times and you are done.
Apr 23, 2007 at 6:51 PM
