Fuel mixture problem when cold
MERCURY SABLE
BO TUNESTAM
1992 Sable 3.0 engine with 155,000 miles. Starts when cold but dies as soon as it's put in gear and accelerator is depressed. After it has warmed up for several minutes, the car runs fine.
I have replaced the temperature sensor and cleaned the air flow regulator that is supposed to adjust the fuel when the engine is cold. No improvement.
The thermostat may also need to be replaced since it appears to be running warm (about 2/3 of the way up the gauge when warmed up).
Any ideas?
Oct 5, 2007 at 10:42 AM
Check the TPS might have a dead spot -The PCM might not realize the throttle is at idle- may give too much fuel or not enough causing to stall.
Oct 5, 2007 at 12:12 PM
