The linkage, slider, ? between the key and the ignition switch does not "link" anything together.
The key Ignition Lock Cylinder works properly and the Ignition Switch, located underneath the steering column, works fine.
I can start the car by moving the slider peg on that ignition switch box. It seems that there is nothing linked between the The key Ignition Lock Cylinder and the ignition switch.
Since that needed link is located inside of the steering column, is there a way to fix it, or do I need a new column?
May 23, 2007 at 1:55 PM
