The transmission had been working fine until yesterday. While accelerating from a stop I had only reached about 10 mph when suddenly the transmission disengaged. I coasted into a parking lot and the transmission acted as if it were in neutral. After I came to a stop I tried reverse & overdrive, drive & first but the transmission was like it was in neutral.
I pulled the codes and this is what I got: Freeze frame was P0750 at 777 rpm.
I also retrieved other codes P1747, P0743, P0750, P0760 and P1451. I checked all the fuses and they were fine. I switch the PCM relay with the Fan relay & still neutral. Can I fix this myself by changing the Shift solenoid A, or is it in the transmission and not accessible. Does the transmission need to be overhauled.
Thank you,
J Goth
Thank you,
J Goth
Mar 8, 2010 at 8:01 PM
