dash board lights
2003 MERCURY SABLE
12,700 MILES • V8 • FWD • AUTOMATIC
TCOLLINS12
when i turn on head lights, the inside dash board lights do not turn on, is this a wiring problem or hopefully a fuse replacement?
Jan 15, 2010 at 12:16 PM
BMRFIXIT
  • 19,053 POSTS
It sounds like you need a headlight switch but to be sure check for power coming out of the dark blue and white tracer wire from the headlight switch.
Here is a guide and the headlight wiring diagram to confirm the failure.
Please let us know what you find.
Cheers
Jan 17, 2010 at 7:05 AM
TCOLLINS12
Thanks for the guides I tested the headlight switch and it was bad so I replaced it now all the lights work. Thanks I love this site.
Jan 18, 2010 at 7:25 AM
R. DAVE JAMES
2001 Mercury Sable Two Wheel Drive Automatic 73000 miles
Please advise of the likely problems with my dash board lights and possible repair solution
Aug 6, 2019 at 3:22 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
Check fuses
check switch
suspect bulbs in the rear of the cluster and need to remove and replace bulbs
FRUGAL1
my dashboard lights sometime work and sometimes dont work. I dont think its the light switch since the lights go no at the radio and other controls. When the dash lights are out the two driectional lights stay on, unless I activate the directionals or 4-ways.
BMRFIXIT
  • 19,053 POSTS
Its a mater of checking and locating a short or a loose connector
overheated wire will cause the same too
i would start with the light switch and its connectors
JBFINCH
I have a 2001 Sable with an identical issue. Have not traced wires yet, but suspected a bad connection somewhere. fun fun.
FRUGAL1
The problem was with the circuit board behind the speedometer cluster. You can change just the circuit board which I purchased from Ford. It was time consuming for a do it yourselfer but everything is working now.
