2003 Mercury Sable car trouble
2003 MERCURY SABLE
224,000 MILES • 6 CYL • FWD • AUTOMATIC
TONIYA CRUMP
my car starts some of the time some one said it sounds like it is not cathhing gas
Jul 3, 2010 at 8:13 AM
Next time it refuses to start-What you need to do is determine if its a fuel or spark problem that's preventing it from starting-Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Jul 3, 2010 at 8:19 AM
