[quote:6e226fe534="Doug Morland"]Thanks, I figured that part out. I'm not sure if your intent was meant to be sarcastic or something?
I HAVE tried "reaching around", looking around, trying a mirror, even up from underneath and I did get a practical solution from someone who said to undo the R.Cowl Screen, R.Cowl and the ignition coil. I'm reluctant to try that as there seem to be a lot of connections that I'm afraid to disturb without me really knowing a lot about the whole thing. It's amazing how difficult it seems to be to make an attempt to do these repairs by yourself?
Any other ideas out there?
Thanks again...Doug M.[/quote:6e226fe534]
Doug, you can reach your plugs by removing the coil pack, but even then it's a very tight fit.I find it just as easy and quick to remove the plentum as Merlin says and gives you plenty of room. If you do remove the plentum, you might consider to replace your plug wires if they are original. It really sucks to do all that work and then a month later have a plug wire go bad.
Nov 26, 2018 at 12:20 PM
(Merged)
