2002 Mercury Sable car is pulling back on acceleration
2002 MERCURY SABLE
CARFORM
2002 Mercury Sable V8 Four Wheel Drive Automatic
Is this a transmission problem or something else?
Feb 8, 2010 at 9:25 PM
Inspect and test all the following listed below:
Oxygen sensor
Catalytic converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Cap and rotor
Note:If it doesn't apply disregard.
Feb 8, 2010 at 11:30 PM
