Hello
Thanks for the donation
It sounds like you have hit the nail on the head, so to speak.
If you have a defective brake light switch, it will not allow you to shift if in an automatic car properly. As you know, you have to depress the brake to put the car in gear; with this broken your car does not know you are pressing the brake and doesn't send the signal to the interlock shifter system.
If you need assistance with replacing the switch, just reply to this post and I will follow up with instructions.
Thanks for using 2carpros.com!
Dec 5, 2008 at 11:40 PM
