2001 Mercury Sable Transmission trouble
2001 MERCURY SABLE
101,000 MILES • 6 CYL • FWD • AUTOMATIC
2IUFANS
My 2001 Mercury sable is not shifting down the way it should. If I drive like 30 mph and stop and try to go it will jump because it hasn't shifted all the way down. The fluid was low, I checked with the motor running and added some. Also, when i had the dip stick out and shut the car off, the fluid started bubbling up and out of where it goes in and it smelled hot.Could this be caused by a bad filter or does it sound like a problem i need to have a professional fix?
Oct 25, 2010 at 10:57 AM
Is the fluid still clean? Does it have a burnt smell? Have any warning lights come on?
Oct 25, 2010 at 3:20 PM
2IUFANS
Yes fluid is clean, did smell hot. No lights
Oct 26, 2010 at 7:38 AM
It sounds like the trans control module (TCM) is bad. I would recommend having it checked.
Oct 26, 2010 at 10:20 AM
