air compressor
2001 MERCURY SABLE
80,000 MILES • 6 CYL • FWD • AUTOMATIC
JMILLERSCCB
local shop tells me that belt is bad as car has been making noise and that entire a/c compressor must be replaced. Is this correct? couldn't belt be replaced immediately and compressor later?
Feb 17, 2010 at 12:57 PM
This depends on if the compressor is locked up or not. If the compressor is not spinning, then the belt will just break due to the pulley not spinning, it is locked up. So, the belt will not be able to turn it and it will overheat and snap the belt.
https://www.2carpros.com/articles/replace-serpentine-belt
So can you let us know if the compressor is locked up and we can go from there.
If it is, then the only solution would be to replace it or bypass it with a smaller belt or a bypass pulley.
https://www.2carpros.com/articles/replace-air-conditioner-compressor
Please run through this and let us know what is happening and we can go from there.
Thanks
Apr 21, 2022 at 6:48 PM
