low beams dont work but all other lights do i have checked all fuses relays and switches everything checks out great cant figure this out.
Aug 2, 2010 at 7:10 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
this is normally a sign that there is a bulb that is not working properly. test ALL bulbs, not just the headlight bulbs.
Aug 2, 2010 at 10:11 PM
SIXSHOOTER
MEMBER
what if everything checks out then what, cause everthing else works perfect.
Aug 3, 2010 at 7:38 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
if your certain everything was good then must be wiring issue somewhere, either at dimmer switch or at one of the light assemblies.
Aug 3, 2010 at 8:38 PM
BRAVESTAR1
CERTIFIED EXPERT
It could also be a ground problem with one of the wires that connects back to the cars subframe. I am working on this same issue with a 2002 Ford Taurus right now.
Aug 12, 2010 at 8:26 PM
SIXSHOOTER
MEMBER
ok i light tested the plug where the bulb plugs in and every prong is hot dont know if thats normal but they are hot,and i know the bulb is good i checked it in another car and its good any ideas thanks for all the info sofar
Aug 14, 2010 at 7:31 PM
SIXSHOOTER
MEMBER
man if you get yours figured out please let me know what it was and ill do the same thanks for the info.
