1999 Mercury Sable SURGING
1999 MERCURY SABLE
103,000 MILES • 6 CYL • FWD • AUTOMATIC
NYANDJIM
When accelerating modestly, the engine often seems to falter momentarily, and then surges for a second, and then settles back to normal acceleration.
Did the 100k tune up at 98,000k and this problem is unchanged.
Is this the computer?
Sep 2, 2010 at 8:07 AM
Hi nyandjim, Welcome to 2carpros and TY for the donation
Lack of acceleration,chugging,hesitating,bogging,misfiring etc. could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Sep 2, 2010 at 8:55 AM
