1999 Mercury Sable Cruise and Horn Suddenly Inoperative
1999 MERCURY SABLE
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
GAS2001TECH
The cruise control on this 1999 Sable has suddenly stopped working. After some troubleshooting, I think I have ruled out the fuses and brake switch. During the process, I found the horn does not work. Am I looking at a steering column pull job?
Thanks
Jul 31, 2010 at 1:28 PM
MERLIN2021
  • 17,250 POSTS
you are most likely looking at the clockspring, you do need to remove the steering wheel.
Jul 31, 2010 at 1:32 PM
GAS2001TECH
Initially, I checked the fuses under the dash, all were fine. Since there was no common fuse for the Cruise Control and the Horn, I assumed the 2 weren't related, except thru marriage at the steering wheel. After more investigation, I checked the fuse block under the hood, found a blown fuse for the horn (no reference to the Cruise in the owner's manual), replaced it, and the horn and the Cruise now work.
Hope this may save others some looking. Merlin, thanks for the reply. I will save the clockspring question for later, should I need it. Hoping not to.
Thanks again.
Aug 2, 2010 at 7:14 AM
MERLIN2021
  • 17,250 POSTS
OK, I'll be watching out, if it blows again, we will check the steering wheel switches, and the clockspring out.
Aug 2, 2010 at 1:11 PM
