1999 Mercury Sable car at idle
1999 MERCURY SABLE
94,000 MILES • 6 CYL • FWD • AUTOMATIC
STEPHANIEAKATWEETY
  • 4 POSTS
When I'm driving it runs fines but when I get to a stop light and I'm not pressing the gas the car will putt like its not getting any gas then it cuts off. I got it tested and they said both of the oxygen sensors has gone bad. Do you have any advice???
Oct 16, 2010 at 7:22 PM
DRCRANKNWRENCH
  • 3,380 POSTS
There are a lot of possibilities that can cause issues at idle. The first things to check are the cap and rotor, (unless your car has a coil box and does not use a distributor), plug wires and plugs. If there is any question, you should replace them all because they are part of a regular service anyway.
Then there are electrical items that might be at fault. That is part of the challenge with electrical stuff as it will fail slowly, intermittently and in all cases, totally. It can also be an issue where one weak part makes another fail. Overheated electrical will put demands on dependant components and can damage them. I have fixed stuff and had other stuff fail at a later date due to aforementioned situation. So, it is best o go through a process of elimination, but use reason when a part failure can damage other parts when it catastrophically fails.
Before you replace anything, let me know how the plugs look.
Pull the plugs when you get a chance and look at the tip. A brownish tan color is normal. If you find anything else. let me know what it looks like.
The next step will be running a can or 2 of injector and intake tract cleaner. This is the issue for many fuel injected cars having performance an idling problems. I use BG44K as it is the only cleaner that I have found that truly cleans the injectors and intake tract to the pint where even injectors near failure can be saved. You might have to go to a service station or car dealership to find it as auto parts store do not always carry it.
Oct 16, 2010 at 7:55 PM
STEPHANIEAKATWEETY
  • 4 POSTS
Yes I've changed the plugs and wires about two weeks ago. I went to Advance Auto and they did the diagnostic test and said it was the oxygen sensor. Then someone else told me to check the mass air flow sensor and I could clean that before I replace anything. What do you think???
Oct 16, 2010 at 8:12 PM
DRCRANKNWRENCH
  • 3,380 POSTS
If the diagnostic shows that the O2 is bad it is something to look at. Usually the cxar will start to get bad gas maileage when the O2 is bad. But other things can happen and it is a regular service item.
I would not clean a mss air flow sensor becuase they arte easy to damage3. Even when you replace one you have to go to a dealer and have them reflash the ECU to recognize the new MAF. Soetimes people coinfuse it with a MAP that is easier to clean.
Shange the O2 and see wht hapeens.
Oct 17, 2010 at 7:06 PM
STEPHANIEAKATWEETY
  • 4 POSTS
ok now whats the difference between the o2 sensor and the mass air flow? It has been using a lot of gas. I hate to repair one thing n its something else. Money is tight right now. Will driving it while the o2 sensor cause any damage other than burning a lot of gas?
Oct 18, 2010 at 5:59 PM
DRCRANKNWRENCH
  • 3,380 POSTS
The mass air flow sensor is going to be part of the intake path befor the throttle boady and will have an electrical lead coming off of it. It is very delicate because it has 2 very thin wires that are crosshaired in the middle off the air intake. There is a sparay cleaner available but they tend to do much more damage than fixing anything.
The O2 sensor is part of the exhaust and will be in between the exhaust manifold and the catalytic converter. It will also have an electrical lead coming off of it.
The O2 sensor should be replaced every so often as part of a complete service when higher mileage items are included in maintenance. So, between the diagnostics, the behaviour of your car and what my first instinct is, you certainly won't waste any money replacing the O2 sensor.
It is going to be one less thing to worry about either way. I do think this will fix it or in the least will be part of the path to fixing it.
Let me know the outcome and I will keep the post link on top of my list so I can replay ASAP.
I will be moving this week, so it might take me a little longer than usual to get back to you.
Oct 19, 2010 at 12:59 PM
STEPHANIEAKATWEETY
  • 4 POSTS
Ok Thank you I will let you know how it turns out. Hope tou have a good move. They can be tough.
Oct 21, 2010 at 4:55 PM
