[quote:9810c88ffc="dibjim"]how do i get to the rear plugs on my 1999 mercury sable v6 dohc engine? 117,000 miles on car.[/quote:9810c88ffc]
Disconnect the wiring harness from the ignition coil pack, remove the four coil hold-down screws, and remove the coil pack for access to the spark plugs in cylinders 1, 2, and 3. Or, you can remove the entire plantum which is what I do because it gives you more room to pull the plug wire's. You might consider replacing your plug wires if they are original at this time.
Apr 1, 2019 at 5:28 PM
(Merged)
