I have a short in the electrical system causing a 300ma drain on the battery when car is not running. This causes the battery to run down after a couple days to the point the car will not turn over. I have isolated the short to a 5A fuse#23 that is marked WIPE-VAP on fuse cover or GEM. When I pull the fuse out the drain basically goes away and the car will start after many days idle. The car will run fine without the fuse, but the power windows, power door locks, windshield wipers and the remote door locks will not operate. What does the fuse control and where do I look for the problem. Thank you, Eric.
Jun 6, 2010 at 9:14 PM
